소개
Unable to quickly remove your canister from the vacuum body? This guide will show you how to replace the spring inside the opening mechanism.
필요한 것
If the top handle does not pop up when trying to remove canister, press the gray button as you gently pull up on the top handle.
거의 끝나갑니다!
결론
