주요 콘텐츠로 건너뛰기
Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement
필요한 것
  1. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement, Canister Unlocking Mechanism Spring: 1 단계, 이미지 1/1
    • If the top handle does not pop up when trying to remove canister, press the gray button as you gently pull up on the top handle.
  2. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: 2 단계, 이미지 1/1
    • Locate the spring in the small opening between the handle and ball of the vacuum body.
  3. Dyson Cinetic Animal Canister Unlocking Mechanism Spring Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Pull out the spring by carefully inserting tweezers into the opening.
    • Carefully remove the spring.
결론
Allison Turnbaugh
회원 가입일: 01/25/17
213 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-5, Banghart Winter 2017 Cal Poly, Team 9-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S9G5
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 35
전체 시간: 2,457
