주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dyson Corrale HS03 Outer Casing Replacement
필요한 것
  1. Dyson Corrale HS03 Outer Casing Replacement, Outer Casing: 1 단계, 이미지 2개 중 1개 Dyson Corrale HS03 Outer Casing Replacement, Outer Casing: 1 단계, 이미지 2개 중 2개
    • Hold the Dyson with the silver safety lock facing you and push it upward.
    • This opens the heating plates forming a "V."
  2. Dyson Corrale HS03 Outer Casing Replacement: 2 단계, 이미지 3개 중 1개 Dyson Corrale HS03 Outer Casing Replacement: 2 단계, 이미지 3개 중 2개 Dyson Corrale HS03 Outer Casing Replacement: 2 단계, 이미지 3개 중 3개
    • Use a TR6 Torx security screwdriver to remove the screw from the center of the purple hinge bracket on each side of the hinge.
    • Use a Jimmy or spudger to carefully pry up and remove the hinge brackets.
  3. Dyson Corrale HS03 Outer Casing Replacement: 3 단계, 이미지 3개 중 1개 Dyson Corrale HS03 Outer Casing Replacement: 3 단계, 이미지 3개 중 2개 Dyson Corrale HS03 Outer Casing Replacement: 3 단계, 이미지 3개 중 3개
    • Pull off the black cover from the base.
    • Use a TR7 Torx security screwdriver to remove the two screws from the base of the straightener.
  4. Dyson Corrale HS03 Outer Casing Replacement: 4 단계, 이미지 2개 중 1개 Dyson Corrale HS03 Outer Casing Replacement: 4 단계, 이미지 2개 중 2개
    • With your thumb and index fingers, pull the black charging port cover off.
  5. Dyson Corrale HS03 Outer Casing Replacement: 5 단계, 이미지 3개 중 1개 Dyson Corrale HS03 Outer Casing Replacement: 5 단계, 이미지 3개 중 2개 Dyson Corrale HS03 Outer Casing Replacement: 5 단계, 이미지 3개 중 3개
    • Hold the Dyson firmly, supporting one side with one hand while using the other hand to open the opposite side.
    • Pull up on the side you want to open to release it, then repeat on the opposite side.
  6. Dyson Corrale HS03 Outer Casing Replacement: 6 단계, 이미지 2개 중 1개 Dyson Corrale HS03 Outer Casing Replacement: 6 단계, 이미지 2개 중 2개
    • Use a T4 Torx screwdriver to remove the screws from the middle section.
  7. Dyson Corrale HS03 Outer Casing Replacement: 7 단계, 이미지 1개 중 1개
    • Use an opening tool to pop off the silver safety lock.
  8. Dyson Corrale HS03 Outer Casing Replacement: 8 단계, 이미지 3개 중 1개 Dyson Corrale HS03 Outer Casing Replacement: 8 단계, 이미지 3개 중 2개 Dyson Corrale HS03 Outer Casing Replacement: 8 단계, 이미지 3개 중 3개
    • Hold the Dyson firmly with one hand. With the other hand, push down under the black tab while pulling up at the same time to lift and remove the purple casing.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
2다른 기여자 명과 함께
Anahi Ramirez
회원 가입일: 09/10/25
600 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 22
전체 시간: 138
