주요 콘텐츠로 건너뛰기
Dyson DC14 Brush Bar Replacement
필요한 것
  1. Dyson DC14 Brush Bar Replacement, Brush Bar: 1 단계, 이미지 1개 중 1개
    • Turn off the vacuum and unplug it from the outlet.
    • Lay the vacuum on its top so that the brush bar faces you.
  2. Dyson DC14 Brush Bar Replacement: 2 단계, 이미지 3개 중 1개 Dyson DC14 Brush Bar Replacement: 2 단계, 이미지 3개 중 2개 Dyson DC14 Brush Bar Replacement: 2 단계, 이미지 3개 중 3개
    • Using a quarter, turn the three soleplate fasteners 90 degrees to the left.
    • Holding the soleplate on both sides, tilt it down and away from the vacuum.
    • Remove the soleplate from the vacuum.
  3. Dyson DC14 Brush Bar Replacement: 3 단계, 이미지 2개 중 1개 Dyson DC14 Brush Bar Replacement: 3 단계, 이미지 2개 중 2개
    • Turn down the squared tabs on the brushbar so that they face outward.
    • Use a screwdriver to pry the belt up from the brushbar.
    • Be careful not to cut the belt with the screwdriver.
    • While holding the belt, pull the brushbar to the left and remove it from the vacuum.
    • You can let go of the belt when it's free from the brushbar. The belt will not retract into the vacuum.
    • During reassembly, insert the brushbar with the tabs facing outward, then rotate the tabs up to lock the brushbar in place.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Donald Percivalle
회원 가입일: 10/03/12
1,952 평판
안내서 4개를 작성함
Cal Poly, Team 3-22, Amido Fall 2012 Cal Poly, Team 3-22, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G22
4 회원들
안내서 8개를 작성함
16가이드 댓글
Too bad it don't work that easy when reassembling the drive belt over the brush roller. Dyson should reinvent another way and drop dead!
mikemo69 - 답글
Make sure you get all 4 tabs back in before you close it up. It IS a ##&&% to do on some models.
mjpotter - 답글
What bout putting the Belt back on? Or does it Put Itself back On The Roller????
Missing Steps!
Michael - 답글
RE-insert brush bar? You mean insert new brush bar? (Not reinsert the old one like in the picture because after all this is instructions for replacing the brush bar right?) Aakkk!
At the bottom it says "to reassemble follow these instructions backwards"...something like that.
Excuse me I have to scream now.
Nichola - 답글
Thanks, I got you and I know what you meant. Thanks for taking the time to help others.
ronloveflying - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 29
지난 30일: 135
전체 시간: 73,608
