소개
Dyson DC14 models come in two variants; with and without a clutch. For those without a clutch, a single drive belt connects the motor directly to the brush so the brush rotates continuously whenever the motor is on.
This guide is for replacing the drive belts on Dyson DC03, DC04, DC07 and DC14 models equipped with a drive belt clutch. It requires removing the clutch from the vacuum and disassembling it to remove the drive belts.
필요한 것
Place vacuum face down.
Remove the u-bend pipe that connects the canister to the telescopic wand by pressing the release button and pulling straight out.
Pull the clear hose out of the gasket on the right side of the vacuum under the axle.
Pull the hose straight back towards you.
Remove the three T15 torx screws that secure the cover to the brush clutch belt.
Pull the cover of the brush clutch belt out towards you.
Pull belt to the right to remove the belt from the brush clutch axle.
Two clips secure the clutch knob to the clutch assembly. They can be identified by the half moon cutouts in the interior wall of the clutch knob.
Pry the knob off with a flat blade screwdriver.
Slide the knob off the clutch.
Grasp the drive belts and use them as a handle to pull the clutch out of the housing.
Insert a flat blade screwdriver between the side of the housing and the brush drive pulley.
Pry the pulley out of the housing along with the belt.
Once it is clear of the housing, you can pull the belt the rest of the way out by hand.
다른 2명이 해당 안내서를 완성하였습니다.
