소개
One of the biggest reasons you start to get a build up in the radix assembly in the first place is because of reduced airflow due to filter wear. For peak performance and maximum machine lifespan I would change the washable filter every couple of years.
(DYSON917819-01)
필요한 것
Detatch the cyclone assembly from the main unit.
Flip the assembly over and remove the three plastic tabs covering the screws, then remove the screws. When re-assembling note that the screw holes align only in one way.
A good way to remove the tabs is to insert a small flat-head driver between the the tab and turn. (In the place marked in picture.)
Take the the cyclone assembly apart by pulling the two pieces away from each other. Note that these parts may be stuck together so you might have to use some amount of force. You can now remove the gasket between the parts.
When re-assembling note that you have to press the two pieces together really hard until you hear/feel a click.
다른 17명이 해당 안내서를 완성하였습니다.
