소개
This guide will show you how to remove the soleplate on the bottom of the vacuum. This is easily done by removing 3 plastic fasteners that lock the soleplate in place. Follow the steps below to see how this is done.
필요한 것
Lay the vacuum on its side to allow for easy access to the bottom of the cleaner head.
Unlock the sole plate by using a quarter or other flat tool to turn the three plastic bolts counter-clockwise, as indicated on the sole plate.
다른 3명이 해당 안내서를 완성하였습니다.
