주요 콘텐츠로 건너뛰기
Dyson DC39 Origin Steering Assembly Replacement
필요한 것
  1. Dyson DC39 Origin Steering Assembly Replacement, Bin: 1 단계, 이미지 3개 중 1개 Dyson DC39 Origin Steering Assembly Replacement, Bin: 1 단계, 이미지 3개 중 2개 Dyson DC39 Origin Steering Assembly Replacement, Bin: 1 단계, 이미지 3개 중 3개
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: 2 단계, 이미지 3개 중 1개 Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: 2 단계, 이미지 3개 중 2개 Dyson DC39 Origin Steering Assembly Replacement, Steering Assembly: 2 단계, 이미지 3개 중 3개
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
  3. Dyson DC39 Origin Steering Assembly Replacement: 3 단계, 이미지 3개 중 1개 Dyson DC39 Origin Steering Assembly Replacement: 3 단계, 이미지 3개 중 2개 Dyson DC39 Origin Steering Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Luke Matusiak
회원 가입일: 04/26/17
479 평판
안내서 3개를 작성함
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S23G6
3 회원들
안내서 6개를 작성함
1가이드 댓글
Thank you, thank you, thank you!
Robin Hill - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 877
