주요 콘텐츠로 건너뛰기
Dyson DC56 Attachments Replacement
필요한 것
  1. Dyson DC56 Attachments Replacement, Dust Bin: 1 단계, 이미지 1/1
    • Make sure the vacuum is unplugged.
    • Warning: Avoid pressing the red trigger because it will turn on and begin suction.
  2. Dyson DC56 Attachments Replacement: 2 단계, 이미지 1/1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Attachments Replacement: 3 단계, 이미지 1/1
    • Separate the device with the purple button.
  4. Dyson DC56 Attachments Replacement: 4 단계, 이미지 1/1
    • Locate the dust bin's red release lever on the side of the device.
    • Make sure if the dust bin is full you open the vacuum over a trash can.
  5. Dyson DC56 Attachments Replacement: 5 단계, 이미지 1/1
    • Push the red lever to release the dust bin lid.
  6. Dyson DC56 Attachments Replacement: 6 단계, 이미지 1/1
    • Locate the red lever below the vacuum.
  7. Dyson DC56 Attachments Replacement: 7 단계, 이미지 1/1
    • Push the red lever, pull the back up and away from the dust bin to separate them.
  8. Dyson DC56 Attachments Replacement, Attachments: 8 단계, 이미지 1/1
    • Locate two screws at the back of the attachment holder.
  9. Dyson DC56 Attachments Replacement: 9 단계, 이미지 1/1
    • Use a T8-Torque screwdriver to take out the two 26mm screws out.
  10. Dyson DC56 Attachments Replacement: 10 단계, 이미지 1/1
    • Loosen the attachment holder by using a metal spudger.
  11. Dyson DC56 Attachments Replacement: 11 단계, 이미지 1/1
    • Remove the attachment holder.
결론
John Czerkawski
회원 가입일: 10/02/17
427 평판
안내서 4개 작성하였습니다
USF Tampa, Team S10-G1, Thompson Fall 2017 USF Tampa, Team S10-G1, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G1
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 765
