소개
The battery is what makes this vacuum handheld and portable. It can keep the vacuum operational for approximately 3.5 hours.
필요한 것
Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
다른 9명이 해당 안내서를 완성하였습니다.
댓글 9개
Works for the DC44 animal also. :)
Vu Nguyen and contributors should definitely go back in and REVISE these instructions to include the second screw mentioned by Mike 7/29/18. I almost broke my vacuum because I trust iFixit to vet their content. I discovered the second screw after going to another site and only saw Mike’s post after returning here to see if I missed something - I did: I didn’t read his comments!
Yikes! Thanks goodness I read the comments before I too almost broke something by not removing the second screw!
