주요 콘텐츠로 건너뛰기
Dyson DC56 Battery Replacement
필요한 것
  1. Dyson DC56 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the vacuum is unplugged from charger.
    • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
  2. Dyson DC56 Battery Replacement: 2 단계, 이미지 1/1
    • Locate the purple button at the top of the device.
  3. Dyson DC56 Battery Replacement: 3 단계, 이미지 1/1
    • Separate the device with the purple button.
  4. Dyson DC56 Battery Replacement: 4 단계, 이미지 1/1
    • Take out the filter.
  5. Dyson DC56 Battery Replacement: 5 단계, 이미지 1/1
    • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
  6. Dyson DC56 Battery Replacement, Battery screw 2: 6 단계, 이미지 1/1
    • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
  7. Dyson DC56 Battery Replacement: 7 단계, 이미지 1/1
    • Pull the battery pack down and away from the main body and remove it from the device.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Vu Nguyen
회원 가입일: 10/02/17
189 평판
안내서 1개 작성함
USF Tampa, Team S10-G1, Thompson Fall 2017 USF Tampa, Team S10-G1, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G1
4 회원들
안내서 11개 작성하였습니다
댓글 9개
Works for the DC44 animal also. :)
Tina Willman-Hammar - 답글
You left out the removal of the screw above the charging port.
Mike - 답글
And after unscrewing the 2nd screw, you need very fine tweezers to extract it.
This experience has convinced me never to buy a Dyson product. Their manual gives no info about replacing the battery.
Loohan7 - 답글
Vu Nguyen and contributors should definitely go back in and REVISE these instructions to include the second screw mentioned by Mike 7/29/18. I almost broke my vacuum because I trust iFixit to vet their content. I discovered the second screw after going to another site and only saw Mike’s post after returning here to see if I missed something - I did: I didn’t read his comments!
Cliff - 답글
Yikes! Thanks goodness I read the comments before I too almost broke something by not removing the second screw!
Mark Nicoll - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 29
30일 전: 108
전체 시간: 9,918
