주요 콘텐츠로 건너뛰기
Dyson DC58 Battery Pack Replacement
필요한 것
  1. Dyson DC58 Battery Pack Replacement, Bin: 1 단계, 이미지 1개 중 1개
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Battery Pack Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Battery Pack Replacement: 3 단계, 이미지 1개 중 1개
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Battery Pack Replacement: 4 단계, 이미지 2개 중 1개 Dyson DC58 Battery Pack Replacement: 4 단계, 이미지 2개 중 2개
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Battery Pack Replacement, Battery Pack: 5 단계, 이미지 2개 중 1개 Dyson DC58 Battery Pack Replacement, Battery Pack: 5 단계, 이미지 2개 중 2개
    • Locate the 10mm screw on the side of the battery pack closest to the purple cyclone of the vacuum
    • Use the 2.0 Phillips head screwdriver to remove the 10mm screw
  6. Dyson DC58 Battery Pack Replacement: 6 단계, 이미지 2개 중 1개 Dyson DC58 Battery Pack Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the 10mm screw on the back of the handle on the opposite side of the red trigger button
    • Use the 2.0 philips head screwdriver to remove the 10mm screw
  7. Dyson DC58 Battery Pack Replacement: 7 단계, 이미지 3개 중 1개 Dyson DC58 Battery Pack Replacement: 7 단계, 이미지 3개 중 2개 Dyson DC58 Battery Pack Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the base of the vacuum down, away from the main body
결론
다른 60명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Krista St Onge
회원 가입일: 09/17/15
2,212 평판
안내서 2개를 작성함
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015 회원
CSUF-BRUCE-F15S2G4
4 회원들
안내서 19개를 작성함
17가이드 댓글
I paid just £30 for a black & decker dust buster 10yrs ago & you tell me you want £60 for a replacement battery pack after 3yrs. Dyson has to do better. Your records don’t show that you agreed to replace the pack while the product was under gaurantee so this battery isn’t even 2yrs old!
lucialucia21 - 답글
Great illustration.
apple - 답글
mine isn;’t even a year old
M Donahue - 답글
Yup we have three stain animals in our house two are just over one year old and the other is a little over two years. None of them hold a charge anymore
swelch19673 - 답글
Had a dyson V8 Animal a little under two years and already needing a new battery.
Think I will go back to using a corded machine which lasts a lot longer and costs a lot less to buy. Sorry dyson but I’m not impressed.
Doug Mummery - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 201
지난 30일: 523
전체 시간: 199,715
