주요 콘텐츠로 건너뛰기
Dyson DC58 Cyclone Replacement
필요한 것
  1. Dyson DC58 Cyclone Replacement, Bin: 1 단계, 이미지 1개 중 1개
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Cyclone Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Cyclone Replacement: 3 단계, 이미지 1개 중 1개
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Cyclone Replacement: 4 단계, 이미지 2개 중 1개 Dyson DC58 Cyclone Replacement: 4 단계, 이미지 2개 중 2개
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Cyclone Replacement, Main Body: 5 단계, 이미지 1개 중 1개
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Cyclone Replacement: 6 단계, 이미지 2개 중 1개 Dyson DC58 Cyclone Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Cyclone Replacement: 7 단계, 이미지 1개 중 1개
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
  8. Dyson DC58 Cyclone Replacement, Cyclone: 8 단계, 이미지 2개 중 1개 Dyson DC58 Cyclone Replacement, Cyclone: 8 단계, 이미지 2개 중 2개
    • Use the metal spudger placed between the black rim and the purple rim to separate the purple screen cover from the cyclone body.
    • Pry all the way around the screen cover.
  9. Dyson DC58 Cyclone Replacement: 9 단계, 이미지 1개 중 1개
    • Use a T9 screw driver to remove the five 14mm screws around the edge of the cyclone body.
  10. Dyson DC58 Cyclone Replacement: 10 단계, 이미지 2개 중 1개 Dyson DC58 Cyclone Replacement: 10 단계, 이미지 2개 중 2개
    • Pull down on the black tube-like part of the silver cyclone body to remove it from the cyclone of the Dyson.
    • You may need to wiggle the tube as you are pulling down to loosen the pieces apart.
결론
다른 22명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Herllaine Asistio
회원 가입일: 09/17/15
239 평판
안내서 1개를 작성함
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015 회원
CSUF-BRUCE-F15S2G4
4 회원들
안내서 19개를 작성함
11가이드 댓글
Great job, very useful thanks
Don - 답글
Fantastic thanks!!!!
robh - 답글
Very helpful indeed.
macx - 답글
Thanks. Had to wash out the dog smell. This did the trick.
David Parsons - 답글
Thanks. Had to wash out the dog smell. This did the trick when new filters wouldn't. Shame on Dyson for not making an easier to clean vacuum.
David Parsons - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 47
지난 30일: 200
전체 시간: 27,067
