주요 콘텐츠로 건너뛰기
Dyson DC58 Main Body Replacement
필요한 것
동영상 개요
  1. Dyson DC58 Main Body Replacement, Bin: 1 단계, 이미지 1개 중 1개
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Main Body Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Main Body Replacement: 3 단계, 이미지 1개 중 1개
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Main Body Replacement: 4 단계, 이미지 2개 중 1개 Dyson DC58 Main Body Replacement: 4 단계, 이미지 2개 중 2개
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Main Body Replacement, Main Body: 5 단계, 이미지 1개 중 1개
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Main Body Replacement: 6 단계, 이미지 2개 중 1개 Dyson DC58 Main Body Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Main Body Replacement: 7 단계, 이미지 1개 중 1개
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Krista St Onge
회원 가입일: 09/17/15
2,212 평판
안내서 2개를 작성함
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015 회원
CSUF-BRUCE-F15S2G4
4 회원들
안내서 19개를 작성함
4가이드 댓글
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - 답글
Has anyone replaced the red release catch?
chrisashton1 - 답글
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - 답글
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 24
지난 30일: 59
전체 시간: 14,007
