주요 콘텐츠로 건너뛰기
Dyson Pure Cool AM11 Filter Replacement
  1. Dyson Pure Cool AM11 Filter Replacement, Filter: 1 단계, 이미지 2개 중 1개 Dyson Pure Cool AM11 Filter Replacement, Filter: 1 단계, 이미지 2개 중 2개
    • Ensure the Dyson Pure Cool AM11 is turned off and unplugged from the power source.
    • Stand in front of the device. Firmly grasp the base and the top section. Twist the top section counterclockwise (to your left) to unlock it.
    • Gently lift it away from the base to expose the filter.
  2. Dyson Pure Cool AM11 Filter Replacement: 2 단계, 이미지 3개 중 1개 Dyson Pure Cool AM11 Filter Replacement: 2 단계, 이미지 3개 중 2개 Dyson Pure Cool AM11 Filter Replacement: 2 단계, 이미지 3개 중 3개
    • Grasp the filter housing and pull it upwards to remove it from the device.
    • Take the filter out from the housing.
    • Dispose of it according to your local waste disposal regulations.
  3. Dyson Pure Cool AM11 Filter Replacement: 3 단계, 이미지 3개 중 1개 Dyson Pure Cool AM11 Filter Replacement: 3 단계, 이미지 3개 중 2개 Dyson Pure Cool AM11 Filter Replacement: 3 단계, 이미지 3개 중 3개
    • Unbox your new Dyson filter. Remove any packaging or plastic wrapping.
    • Align the new filter with the housing and then put it back to the base of the device.
    • The filter should fit snugly inside the base. Ensure it is seated correctly and evenly all around.
    • Place the top section back onto the base. Align the two parts and twist the top section clockwise (to your right) until it locks into place.
    • Plug the device back in and turn it on to ensure it’s working properly with the new filter.
결론
Your Dyson Pure Cool AM11 should now be operating with a new, clean filter. Regular filter replacement is key to maintaining the efficiency and longevity of your air purifier.
작성자
1다른 기여자 명과 함께
Zepei
회원 가입일: 11/01/23
255 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 회원
UMASSD-GULBRANDSEN-F23S2G7
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 58
전체 시간: 1,300
