주요 콘텐츠로 건너뛰기
Dyson Pure Cool AM11 Oscillation Motor Replacement
필요한 것
  1. Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: 1 단계, 이미지 3개 중 1개 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: 1 단계, 이미지 3개 중 2개 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: 1 단계, 이미지 3개 중 3개
    • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
  2. Dyson Pure Cool AM11 Oscillation Motor Replacement: 2 단계, 이미지 3개 중 1개 Dyson Pure Cool AM11 Oscillation Motor Replacement: 2 단계, 이미지 3개 중 2개 Dyson Pure Cool AM11 Oscillation Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Remove all 3 tabs that you unscrewed.
  3. Dyson Pure Cool AM11 Oscillation Motor Replacement: 3 단계, 이미지 2개 중 1개 Dyson Pure Cool AM11 Oscillation Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
    • Remove the two screws connected to the rotation arm.
  4. Dyson Pure Cool AM11 Oscillation Motor Replacement: 4 단계, 이미지 3개 중 1개 Dyson Pure Cool AM11 Oscillation Motor Replacement: 4 단계, 이미지 3개 중 2개 Dyson Pure Cool AM11 Oscillation Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the base of the housing from the rest of the fan.
    • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
  5. Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: 5 단계, 이미지 2개 중 1개 Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: 5 단계, 이미지 2개 중 2개
    • Using a T20 Torx screwdriver, remove the two screws on either side of the motor.
  6. Dyson Pure Cool AM11 Oscillation Motor Replacement: 6 단계, 이미지 2개 중 1개 Dyson Pure Cool AM11 Oscillation Motor Replacement: 6 단계, 이미지 2개 중 2개
    • (Optionally) Use a jimmy around the edge of the motor to loosen it from its housing.
    • Lift the motor out of its housing.
    • Ensure that you do not grab the motor by the swing arm as you may damage both the motor and surrounding components.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
AidenManchester
회원 가입일: 11/01/23
252 평판
안내서 2개를 작성함
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 회원
UMASSD-GULBRANDSEN-F23S2G7
3 회원들
안내서 5개를 작성함
댓글 2개
Where’d you get the motor
Jon Murch - 답글
any luck finding the proper motor replacement?
Kay -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 45
전체 시간: 729
