주요 콘텐츠로 건너뛰기
Dyson V6 Motorhead Brush Bar Replacement
필요한 것
  1. Dyson V6 Motorhead Brush Bar Replacement, Brush Bar: 1 단계, 이미지 1/1
    • Press the button to disconnect the vacuum head from the connecting pole.
  2. Dyson V6 Motorhead Brush Bar Replacement: 2 단계, 이미지 1/1
    • Turn the end cap counterclockwise using the iFixit Opening Tool.
    • If you do not have an iFixit Opening Tool, a quarter may be used instead.
  3. Dyson V6 Motorhead Brush Bar Replacement: 3 단계, 이미지 1/3 Dyson V6 Motorhead Brush Bar Replacement: 3 단계, 이미지 2/3 Dyson V6 Motorhead Brush Bar Replacement: 3 단계, 이미지 3/3
    • Pull the brush bar out of the housing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Addie Hedge
회원 가입일: 01/24/17
710 평판
안내서 5개 작성하였습니다
Cal Poly, Team 22-6, Maness Winter 2017 Cal Poly, Team 22-6, Maness Winter 2017 회원
CPSU-MANESS-W17S22G6
4 회원들
안내서 5개 작성하였습니다
댓글 4개
Not so fast, there are teeth on the lower roll insert that can interfere with teeth on the housing. Is there a purpose for these teeth, maybe manufacturing mold release? My brush roll will not turn when re-installed. It installs easily, powers up, spins about 4 or 5 revolutions, then shuts off power for a second, then comes back on without the roller spinning at all. I can see it is the teeth interlocking but don’t know how it makes the first 4 or 5 revs. Very strange indeed!!
dooleyew - 답글
I have the same problem, where the teeth seem to be engaging and stopping the revolutions. Any fix for this?
Dave Duddleston - 답글
I have the same problem and I never signed up for the warranty.
Donna Sweeney - 답글
My motorhead works intermittely. I took it apart and cleaned everything to no avail. The guy at Starks vacuum in Sherwood OR said it was plugged and he would take it apart and clean it for $100. Hmmmm, what can he clean that I can’t?
Roger and Karen Risch - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 40
전체 시간: 21,923
