주요 콘텐츠로 건너뛰기
Dyson V6 Motorhead Collection Bin Replacement
  1. Dyson V6 Motorhead Collection Bin Replacement, Connection Tubing: 1 단계, 이미지 1/3 Dyson V6 Motorhead Collection Bin Replacement, Connection Tubing: 1 단계, 이미지 2/3 Dyson V6 Motorhead Collection Bin Replacement, Connection Tubing: 1 단계, 이미지 3/3
    • Depress the button releasing an end of the connection tubing.
    • Pull the connection tubing away from the bottom vacuum head.
  2. Dyson V6 Motorhead Collection Bin Replacement: 2 단계, 이미지 1/3 Dyson V6 Motorhead Collection Bin Replacement: 2 단계, 이미지 2/3 Dyson V6 Motorhead Collection Bin Replacement: 2 단계, 이미지 3/3
    • Depress the last button, freeing the connection tubing.
    • Pull connection tubing away from the upper vacuum head.
  3. Dyson V6 Motorhead Collection Bin Replacement, Collection Bin: 3 단계, 이미지 1/2 Dyson V6 Motorhead Collection Bin Replacement, Collection Bin: 3 단계, 이미지 2/2
    • Pull down on the red release tab.
    • When the tab is fully engaged, the bottom of the bin should open.
  4. Dyson V6 Motorhead Collection Bin Replacement: 4 단계, 이미지 1/2 Dyson V6 Motorhead Collection Bin Replacement: 4 단계, 이미지 2/2
    • Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
  5. Dyson V6 Motorhead Collection Bin Replacement: 5 단계, 이미지 1/3 Dyson V6 Motorhead Collection Bin Replacement: 5 단계, 이미지 2/3 Dyson V6 Motorhead Collection Bin Replacement: 5 단계, 이미지 3/3
    • Pull the collection bin away from the upper vacuum head.
결론
Addie Hedge
회원 가입일: 01/24/17
710 평판
안내서 5개 작성하였습니다
Cal Poly, Team 22-6, Maness Winter 2017 Cal Poly, Team 22-6, Maness Winter 2017 회원
CPSU-MANESS-W17S22G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 3,240
