주요 콘텐츠로 건너뛰기
Dyson V6 Motorhead Motor Replacement
필요한 것
  1. Dyson V6 Motorhead Motor Replacement, Collection Bin: 1 단계, 이미지 2개 중 1개 Dyson V6 Motorhead Motor Replacement, Collection Bin: 1 단계, 이미지 2개 중 2개
    • Pull down on the red release tab.
    • When the tab is fully engaged, the bottom of the bin should open.
  2. Dyson V6 Motorhead Motor Replacement: 2 단계, 이미지 2개 중 1개 Dyson V6 Motorhead Motor Replacement: 2 단계, 이미지 2개 중 2개
    • Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
  3. Dyson V6 Motorhead Motor Replacement: 3 단계, 이미지 3개 중 1개 Dyson V6 Motorhead Motor Replacement: 3 단계, 이미지 3개 중 2개 Dyson V6 Motorhead Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Pull the collection bin away from the upper vacuum head.
  4. Dyson V6 Motorhead Motor Replacement, Motor: 4 단계, 이미지 1개 중 1개
    • Identify the two white components between the vacuum handle and the attached component.
  5. Dyson V6 Motorhead Motor Replacement: 5 단계, 이미지 2개 중 1개 Dyson V6 Motorhead Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Insert each arm of the tweezer into each white component area and squeeze simultaneously to release the motor from the attached component.
  6. Dyson V6 Motorhead Motor Replacement: 6 단계, 이미지 2개 중 1개 Dyson V6 Motorhead Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Detach the motor from the remaining motor head assembly.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Addie Hedge
회원 가입일: 01/24/17
710 평판
안내서 5개를 작성함
Cal Poly, Team 22-6, Maness Winter 2017 Cal Poly, Team 22-6, Maness Winter 2017 회원
CPSU-MANESS-W17S22G6
4 회원들
안내서 5개를 작성함
3가이드 댓글
really good can understand and not too technical
kelvin - 답글
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
Chris Tadda - 답글
Can't see the tweezer being inserted into the white tabs. Picture not clear. Could not dislodge motorhead from cannister bin. Show a clearer picture. Thanks
Hem - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 58
전체 시간: 19,864
