이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
Turn device completely over to view battery pack.
Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery pack.
다른 51명이 해당 안내서를 완성하였습니다.
댓글 13개
I have replaced the battery and I still got a flashing red light, any ideas
I replaced my battery and charged the new one- my vac doesnt work
grooveon.g - 답글
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
