주요 콘텐츠로 건너뛰기
Dyson V8 Absolute Bin Replacement
필요한 것
  1. Dyson V8 Absolute Bin Replacement, Bin: 1 단계, 이미지 1개 중 1개
    • Set the device upright on a flat surface and detach the wand.
    • Pull the red bin release trigger, on top of the cyclone. This will require some force.
  2. Dyson V8 Absolute Bin Replacement: 2 단계, 이미지 2개 중 1개 Dyson V8 Absolute Bin Replacement: 2 단계, 이미지 2개 중 2개
    • Pull up on the latch until it's fully extend.
    • The bin will open to dispense debris once the red latch is pulled.
  3. Dyson V8 Absolute Bin Replacement: 3 단계, 이미지 2개 중 1개 Dyson V8 Absolute Bin Replacement: 3 단계, 이미지 2개 중 2개
    • Push the red circular button to release the latch on the cyclone.
    • The cyclone should release and be fully detached from the device.
  4. Dyson V8 Absolute Bin Replacement: 4 단계, 이미지 2개 중 1개 Dyson V8 Absolute Bin Replacement: 4 단계, 이미지 2개 중 2개
    • Push on the red release button on the bottom of the bin.
    • The bin should slide away from the handle.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Miranda Laberge
회원 가입일: 10/19/17
697 평판
안내서 2개를 작성함
UW Tacoma, Team S1-G5, Rose Fall 2017 UW Tacoma, Team S1-G5, Rose Fall 2017 회원
UWT-ROSE-F17S1G5
4 회원들
안내서 16개를 작성함
2가이드 댓글
My bin seems to be more difficult to open all of the sudden and I have taken it all apart and put it back together. Still having the issue where the bin doesnt open when the cyclone pops up. HELP please
Rob Coughlin - 답글
I have a Dyson v8 and the red release button is stuck. What do I do.
Pamela Wanklyn - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 31
지난 30일: 128
전체 시간: 22,782
