주요 콘텐츠로 건너뛰기
Dyson V8 Absolute Bin Replacement
필요한 것
  1. Dyson V8 Absolute Bin Replacement, Bin: 1 단계, 이미지 1/1
    • Set the device upright on a flat surface and detach the wand.
    • Pull the red bin release trigger, on top of the cyclone. This will require some force.
    I am unable to open the n. Red button is stuck shut. Is there another way to get it open?
    Helen Ruckman - 답글
    I have had the unit for quite a while and this is the first time it has been stuck shut.
    Helen Ruckman - 답글
    Every couple of months my bin sticks firmly and I am unable to open it. This has now required two return visits to the shop where I bought it, and still it happens regularly. For a top of the range Dyson which cost me around $900, it is disappointing. Vacuum is about 18 months old and very carefully looked after.
    Sorry this comment hasn’t helped your problem Helen, nor mine.
    Linda Lang - 답글
  2. Dyson V8 Absolute Bin Replacement: 2 단계, 이미지 1/2 Dyson V8 Absolute Bin Replacement: 2 단계, 이미지 2/2
    • Pull up on the latch until it's fully extend.
    • The bin will open to dispense debris once the red latch is pulled.
  3. Dyson V8 Absolute Bin Replacement: 3 단계, 이미지 1/2 Dyson V8 Absolute Bin Replacement: 3 단계, 이미지 2/2
    • Push the red circular button to release the latch on the cyclone.
    • The cyclone should release and be fully detached from the device.
  4. Dyson V8 Absolute Bin Replacement: 4 단계, 이미지 1/2 Dyson V8 Absolute Bin Replacement: 4 단계, 이미지 2/2
    • Push on the red release button on the bottom of the bin.
    • The bin should slide away from the handle.
    You didn't answer my question how to put bin cover back on bin. You just showed how to remove bin!!! That isn't the problem.
    Donna Madison - 답글
    You didn't answer my question how to attach bin lid which fell off. Please continue and include directions to attach the cover.
    Donna Madison - 답글
결론
다른 4명이 해당 안내서를 완성하였습니다.
Miranda Laberge
회원 가입일: 10/19/17
697 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G5, Rose Fall 2017 UW Tacoma, Team S1-G5, Rose Fall 2017 회원
UWT-ROSE-F17S1G5
4 회원들
안내서 15개 작성하였습니다
댓글 2개
My bin seems to be more difficult to open all of the sudden and I have taken it all apart and put it back together. Still having the issue where the bin doesnt open when the cyclone pops up. HELP please
Rob Coughlin - 답글
I have a Dyson v8 and the red release button is stuck. What do I do.
Pamela Wanklyn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 39
30일 전: 133
전체 시간: 20,316
