주요 콘텐츠로 건너뛰기
소개
In the case of a smelly device or loss of suction, a filter cleaning or replacement may help to maintain the Dyson V8 Absolute. It is important that the filters are cleaned frequently, at least once a month. The device contains a pre-filter and the HEPA filter. The HEPA filter, is filtering post cycled air through the device. The pre-filter is the initial filtering of debris suctioned.
도구
지정된 도구가 없습니다.
  1. First, make sure the device is unplugged.
    • First, make sure the device is unplugged.
    • Pull the pre-filter up by the knob.
  2. Twist the HEPA filter to the left, matching up two black dots on the device and pulling away. Twist the HEPA filter to the left, matching up two black dots on the device and pulling away.
    • Twist the HEPA filter to the left, matching up two black dots on the device and pulling away.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Miranda Laberge
회원 가입일: 2017년 10월 19일
568 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G5, Rose Fall 2017 UW Tacoma, Team S1-G5, Rose Fall 2017 회원
UWT-ROSE-F17S1G5
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
You didn’t cover cleaning
Ric Riester - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 35
30일 전: 193
전체 시간: 18,001
