주요 콘텐츠로 건너뛰기
Dyson V8 Animal Intake Filter Replacement
필요한 것
  1. Dyson V8 Animal Intake Filter Replacement, Intake Filter: 1 단계, 이미지 1/3 Dyson V8 Animal Intake Filter Replacement, Intake Filter: 1 단계, 이미지 2/3 Dyson V8 Animal Intake Filter Replacement, Intake Filter: 1 단계, 이미지 3/3
    • Twist the air intake filter cap counter clock wise.
    • Pull the air intake filter cap away from the handle.
결론
AJ McLean-Scholz
회원 가입일: 01/23/20
723 평판
안내서 5개 작성하였습니다
Cal Poly, Team S19-G1, White Winter 2020 Cal Poly, Team S19-G1, White Winter 2020 회원
CPSU-WHITE-W20S19G1
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Its the post motor exhaust. It’s not an intake. I am only being pedantic because I have spent ages trying to work out the whistling sound and it;s because on max it pushes the HEPA filter on this part out too hard on the catches and the rubber seal does not stay tight.
Jez D - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 27
30일 전: 95
전체 시간: 3,769
