주요 콘텐츠로 건너뛰기
Dyson v6 Absolute Battery Pack Replacement
필요한 것
  1. Dyson v6 Absolute Battery Pack Replacement, Bin: 1 단계, 이미지 1개 중 1개
    • Unplug the device.
  2. Dyson v6 Absolute Battery Pack Replacement: 2 단계, 이미지 1개 중 1개
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Battery Pack Replacement: 3 단계, 이미지 1개 중 1개
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Battery Pack Replacement: 4 단계, 이미지 1개 중 1개
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Battery Pack Replacement, Battery Pack: 5 단계, 이미지 1개 중 1개
    • Locate the screw on the battery pack.
    • Use a Phillips #2 screwdriver to unscrew the battery pack.
  6. Dyson v6 Absolute Battery Pack Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the screw on the device handle.
    • Use a Phillips #2 screwdriver to remove the screw and release the battery pack.
  7. Dyson v6 Absolute Battery Pack Replacement: 7 단계, 이미지 2개 중 1개 Dyson v6 Absolute Battery Pack Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the battery pack down and away from the device.
결론
다른 142명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tabitha Espina Velasco
회원 가입일: 01/23/17
3,702 평판
안내서 5개를 작성함
Washington State, Team 1-2, Staggers Spring 2017 Washington State, Team 1-2, Staggers Spring 2017 회원
WSU-STAGGERS-S17S1G2
2 회원들
안내서 23개를 작성함
30가이드 댓글
very good article 10 out of 10
karl thiele - 답글
Nice article. Not too long or too short. Perfect pictures, too.
timlevin - 답글
Great pictures, very straight forward, and I really appreciate you guys taking the time to put this together. I managed to “kill” my Dyson by getting a little over-zealous with the cleaning. I’m going to take it apart, let it dry completely, and hope that a new battery is the only issue. Anyway, your presentation has given me the courage to go forward - may not work, but…..
Meg Olhasque - 답글
Hi, I bought my Dyson v6 for Christmas 2016. My battery only last few seconds at dis stage. It seems a short time for battery needing replacing. Is this normal .
Ellymck - 답글
I had the same problem with my dyson v6 slim. The battery didn't last long on mine either! I was very disappointed especially when you pay $500 for one of these.
Beverley Mingo -
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 186
지난 30일: 1,031
전체 시간: 303,880
