주요 콘텐츠로 건너뛰기
Dyson v6 Absolute Cyclone Replacement
필요한 것
  1. Dyson v6 Absolute Cyclone Replacement, Bin: 1 단계, 이미지 1/1
    • Unplug the device.
  2. Dyson v6 Absolute Cyclone Replacement: 2 단계, 이미지 1/1
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Cyclone Replacement: 3 단계, 이미지 1/1
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Cyclone Replacement: 4 단계, 이미지 1/1
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Cyclone Replacement, Main Body: 5 단계, 이미지 1/1
    • Separate the bin from the main body of the device.
  6. Dyson v6 Absolute Cyclone Replacement: 6 단계, 이미지 1/1
    • Locate two visible white clips between the main body and the cyclone.
  7. Dyson v6 Absolute Cyclone Replacement: 7 단계, 이미지 1/1
    • Use tweezers to pinch the white clips together.
    • Widely hold the tweezers apart to get them to reach between the two white clips.
    • Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
  8. Dyson v6 Absolute Cyclone Replacement: 8 단계, 이미지 1/2 Dyson v6 Absolute Cyclone Replacement: 8 단계, 이미지 2/2
    • Tilt and pull the main body away from the cyclone.
    • There may be a loud snap when the main body separates from the cyclone.
  9. Dyson v6 Absolute Cyclone Replacement, Cyclone: 9 단계, 이미지 1/1
    • Use the spudger to remove the cyclone.
    • Start at the small opening beneath the place where the cyclone connects to the main body.
    • Work the spudger around the rim of the red screen filter.
    • You will hear popping noises.
  10. Dyson v6 Absolute Cyclone Replacement: 10 단계, 이미지 1/2 Dyson v6 Absolute Cyclone Replacement: 10 단계, 이미지 2/2
    • Use a T9 Torx screwdriver to remove five 14mm screws from the edge of the screen filter body.
  11. Dyson v6 Absolute Cyclone Replacement: 11 단계, 이미지 1/1
    • Remove the filter screen cover away from the cyclone.
    • Pull down on the black tube inside the cyclone body to remove it from the cyclone.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Tabitha Espina Velasco
회원 가입일: 01/23/17
3,594 평판
안내서 5개 작성하였습니다
Washington State, Team 1-2, Staggers Spring 2017 Washington State, Team 1-2, Staggers Spring 2017 회원
WSU-STAGGERS-S17S1G2
2 회원들
안내서 23개 작성하였습니다
댓글 2개
Very helpful presentation. Reassembly was fiddley as the new cyclone was not broken and needed a very firm waggle and push to engage with the motor body. The white clip is not easy to grasp at the same time as the body and the cyclone.
I found three small broken black plastic pieces under the white clip- from the lugs of the old cyclone - that had to be removed, with tweezers, before assembling the body and cyclone.
John Griggs - 답글
Das Zyklon läßt sich noch viel weiter zerlegen!
Tom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 45
30일 전: 207
전체 시간: 20,511
