주요 콘텐츠로 건너뛰기
Dyson v6 Absolute Cyclone Replacement
필요한 것
  1. Dyson v6 Absolute Cyclone Replacement, Bin: 1 단계, 이미지 1개 중 1개
    • Unplug the device.
  2. Dyson v6 Absolute Cyclone Replacement: 2 단계, 이미지 1개 중 1개
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Cyclone Replacement: 3 단계, 이미지 1개 중 1개
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Cyclone Replacement: 4 단계, 이미지 1개 중 1개
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Cyclone Replacement, Main Body: 5 단계, 이미지 1개 중 1개
    • Separate the bin from the main body of the device.
  6. Dyson v6 Absolute Cyclone Replacement: 6 단계, 이미지 1개 중 1개
    • Locate two visible white clips between the main body and the cyclone.
  7. Dyson v6 Absolute Cyclone Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to pinch the white clips together.
    • Widely hold the tweezers apart to get them to reach between the two white clips.
    • Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
  8. Dyson v6 Absolute Cyclone Replacement: 8 단계, 이미지 2개 중 1개 Dyson v6 Absolute Cyclone Replacement: 8 단계, 이미지 2개 중 2개
    • Tilt and pull the main body away from the cyclone.
    • There may be a loud snap when the main body separates from the cyclone.
  9. Dyson v6 Absolute Cyclone Replacement, Cyclone: 9 단계, 이미지 1개 중 1개
    • Use the spudger to remove the cyclone.
    • Start at the small opening beneath the place where the cyclone connects to the main body.
    • Work the spudger around the rim of the red screen filter.
    • You will hear popping noises.
  10. Dyson v6 Absolute Cyclone Replacement: 10 단계, 이미지 2개 중 1개 Dyson v6 Absolute Cyclone Replacement: 10 단계, 이미지 2개 중 2개
    • Use a T9 Torx screwdriver to remove five 14mm screws from the edge of the screen filter body.
  11. Dyson v6 Absolute Cyclone Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the filter screen cover away from the cyclone.
    • Pull down on the black tube inside the cyclone body to remove it from the cyclone.
결론
다른 17명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tabitha Espina Velasco
회원 가입일: 01/23/17
3,702 평판
안내서 5개를 작성함
Washington State, Team 1-2, Staggers Spring 2017 Washington State, Team 1-2, Staggers Spring 2017 회원
WSU-STAGGERS-S17S1G2
2 회원들
안내서 23개를 작성함
3가이드 댓글
Very helpful presentation. Reassembly was fiddley as the new cyclone was not broken and needed a very firm waggle and push to engage with the motor body. The white clip is not easy to grasp at the same time as the body and the cyclone.
I found three small broken black plastic pieces under the white clip- from the lugs of the old cyclone - that had to be removed, with tweezers, before assembling the body and cyclone.
John Griggs - 답글
Das Zyklon läßt sich noch viel weiter zerlegen!
Tom - 답글
Schmutz/Staub an den Plastikteilen nach Zerlegung lassen sich gut im Eimer mit Seifenwasser auflösen.
Wieder zusammenbauen erst nach kompletten Trocknen !
Macht mal Fotos von verdrecktem Zyklon.
RepairUli - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 55
지난 30일: 177
전체 시간: 24,111
