주요 콘텐츠로 건너뛰기
Dyson v6 Absolute Main Body Replacement
필요한 것
  1. Dyson v6 Absolute Main Body Replacement, Bin: 1 단계, 이미지 1개 중 1개
    • Unplug the device.
  2. Dyson v6 Absolute Main Body Replacement: 2 단계, 이미지 1개 중 1개
    • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
    • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
  3. Dyson v6 Absolute Main Body Replacement: 3 단계, 이미지 1개 중 1개
    • Push the red lever down a second time to release the debris bin.
  4. Dyson v6 Absolute Main Body Replacement: 4 단계, 이미지 1개 중 1개
    • Pull bin away from the cyclone.
  5. Dyson v6 Absolute Main Body Replacement, Main Body: 5 단계, 이미지 1개 중 1개
    • Separate the bin from the main body of the device.
  6. Dyson v6 Absolute Main Body Replacement: 6 단계, 이미지 1개 중 1개
    • Locate two visible white clips between the main body and the cyclone.
  7. Dyson v6 Absolute Main Body Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to pinch the white clips together.
    • Widely hold the tweezers apart to get them to reach between the two white clips.
    • Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
  8. Dyson v6 Absolute Main Body Replacement: 8 단계, 이미지 2개 중 1개 Dyson v6 Absolute Main Body Replacement: 8 단계, 이미지 2개 중 2개
    • Tilt and pull the main body away from the cyclone.
    • There may be a loud snap when the main body separates from the cyclone.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tabitha Espina Velasco
회원 가입일: 01/23/17
3,702 평판
안내서 5개를 작성함
Washington State, Team 1-2, Staggers Spring 2017 Washington State, Team 1-2, Staggers Spring 2017 회원
WSU-STAGGERS-S17S1G2
2 회원들
안내서 23개를 작성함
1가이드 댓글
The motorhead does not rotate or only works irregularly?
There are two little metal tabs sitting above the lever of the bin and are meant to make electrical contact to the wires running around the bin and down the wand to the motorhead to power the rotating brush. Those metal-tabs tend to get bend and/or their ends might have become dislocated out of their brackets.
Thanks for Your guide!!! It helped me to remove the Main Body from the Cyclone properly and get those metal-tabs back in place.
Robert Hoppe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 30
지난 30일: 150
전체 시간: 23,638
