주요 콘텐츠로 건너뛰기
E46 M3 door card/panel removal
필요한 것
  1. E46 M3 door card/panel removal, Identify the screws: 1 단계, 이미지 1/1
    • The door card is held securely in place with 5 screws.
    • Keep in mind the door card has up to 3 wire bundles attached to it. Be careful when removing it! Be prepared to support it while dealing with the wires.
  2. E46 M3 door card/panel removal, Remove screw covers: 2 단계, 이미지 1/2 E46 M3 door card/panel removal, Remove screw covers: 2 단계, 이미지 2/2
    • Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger.
    • Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
  3. E46 M3 door card/panel removal, Remove bolts: 3 단계, 이미지 1/1
    • Using a T20 Torx driver with extension, remove all 5 bolts.
  4. E46 M3 door card/panel removal, Remove mirror control: 4 단계, 이미지 1/1
    • If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
  5. E46 M3 door card/panel removal, Pop door card clips: 5 단계, 이미지 1/2 E46 M3 door card/panel removal, Pop door card clips: 5 단계, 이미지 2/2
    • Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame.
    • After you've released the bottom clips, work your way around.
    • You will need to lift the door card from the door frame in order to fully release it. Be careful!
    • Disconnect the following from the door panel:
    • Unlocking cable
    • Speaker cable(s)
    • Set the door panel aside.
  6. E46 M3 door card/panel removal, Door panel removed!: 7 단계, 이미지 1/1
    • The door panel is now removed.
    • You will see the airbag module, vapor barrier, and other components.
결론
To reassemble your door, follow these instructions in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
Dom Santangelo
회원 가입일: 09/19/16
592 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 48
30일 전: 153
전체 시간: 14,752
