주요 콘텐츠로 건너뛰기
EDCO Floor Stripper TS8 .75L (2017) Belt Replacement
필요한 것
  1. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Safety precautions: 1 단계, 이미지 1/1
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the machine is unplugged.
    • Turn the power switch counterclockwise into the OFF position.
  2. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood bolts: 2 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood bolts: 2 단계, 이미지 2/2
    • Use a 1/2 inch socket to remove the four bolts securing the hood to the frame, two on each side.
    • During reassembly, ensure each bolt is reinstalled with both its flat washer and lock washer.
  3. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood: 3 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the hood: 3 단계, 이미지 2/2
    • Pull the hood away from the device to remove it.
  4. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Loosen the motor mount bolts: 4 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Loosen the motor mount bolts: 4 단계, 이미지 2/2
    • Use a 9/16 inch socket to loosen, but not remove, the four bolts securing the motor mount to the frame, two on each side.
  5. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Slide motor mount forward: 5 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Slide motor mount forward: 5 단계, 이미지 2/2
    • Slide the motor towards the front of the device to release tension in the belt."
    • Reassembly tip: Tilt the device onto its handles to use the weight of the motor to tension the belt, then tighten down the bolts.
  6. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the belt: 6 단계, 이미지 1/3 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the belt: 6 단계, 이미지 2/3 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement, Remove the belt: 6 단계, 이미지 3/3
    • Remove the belt from the cam shaft pulley.
  7. EDCO Floor Stripper TS8 .75L (2017) Belt Replacement: 7 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Belt Replacement: 7 단계, 이미지 2/2
    • Disengage the belt from the motor pulley.
    • Remove the belt.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Robert Boyd
회원 가입일: 02/01/21
26,243 평판
안내서 94개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 16
전체 시간: 400
