주요 콘텐츠로 건너뛰기
EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement
필요한 것
  1. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Safety precautions: 1 단계, 이미지 1/1
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the machine is unplugged.
    • Turn the power switch counterclockwise into the OFF position.
  2. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the hood bolts: 2 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the hood bolts: 2 단계, 이미지 2/2
    • Use a 1/2 inch socket to remove the four bolts securing the hood to the frame, two on each side.
    • During reassembly, ensure each bolt is reinstalled with both its flat washer and lock washer.
  3. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the hood: 3 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the hood: 3 단계, 이미지 2/2
    • Pull the hood away from the device to remove it.
  4. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Loosen the motor mount bolts: 4 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Loosen the motor mount bolts: 4 단계, 이미지 2/2
    • Use a 9/16 inch socket to loosen, but not remove, the four bolts securing the motor mount to the frame, two on each side.
  5. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Slide motor mount forward: 5 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Slide motor mount forward: 5 단계, 이미지 2/2
    • Slide the motor towards the front of the device to release tension in the belt."
    • Reassembly tip: Tilt the device onto its handles to use the weight of the motor to tension the belt, then tighten down the bolts.
  6. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the belt: 6 단계, 이미지 1/3 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the belt: 6 단계, 이미지 2/3 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the belt: 6 단계, 이미지 3/3
    • Remove the belt from the cam shaft pulley.
  7. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 7 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 7 단계, 이미지 2/2
    • Disengage the belt from the motor pulley.
    • Remove the belt.
  8. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Tilt the device: 8 단계, 이미지 1/3 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Tilt the device: 8 단계, 이미지 2/3 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Tilt the device: 8 단계, 이미지 3/3
    • Tilt the device back to rest on its handle.
    • Ensure that the four 9/16 inch motor mount bolts are tightened before tilting the device.
  9. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Chock the wheels: 9 단계, 이미지 1/1
    • Insert wheel chocks behind the wheels to ensure the device does not move or fall during the repair."
  10. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the blade retainer: 10 단계, 이미지 1/1
    • Use a 3/16 inch hex key to remove the three bolts securing the blade retainer.
  11. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 11 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 11 단계, 이미지 2/2
    • Remove the blade retainer.
  12. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Loosen set screws: 12 단계, 이미지 1/1
    • Use a 1/8 inch hex key to loosen the two set screws on the lower flange bearing.
  13. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 13 단계, 이미지 1/1
    • Use a 1/8 inch hex key to loosen the two set screws on the middle flange bearing.
    • These set screws require either a long hex key or an extension to reach. They can be accessed from the front of the floor stripper or from the slots on either side of the frame.
  14. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 14 단계, 이미지 1/1
    • Use a 9/16 inch socket to remove the two nuts securing the upper flange bearing to the frame.
    • If you are unable to fit a socket on the nuts due to the cam shaft pulley, try using a wrench.
    • If the bolts spin without loosening, use a 9/16 inch wrench to hold the bolt head from underneath.
  15. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the cam shaft assembly: 15 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement, Remove the cam shaft assembly: 15 단계, 이미지 2/2
    • Use a mallet and an appropriately-sized brass punch to tap out the cam shaft assembly if you cannot remove it by hand.
    • Once loose, the cam shaft assembly can fall out quickly.
  16. EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 16 단계, 이미지 1/2 EDCO Floor Stripper TS8 .75L (2017) Cam Shaft Assembly Replacement: 16 단계, 이미지 2/2
    • Remove the cam shaft assembly
결론
Robert Boyd
회원 가입일: 02/01/21
26,500 평판
안내서 94개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 388
