소개
Follow this guide to remove and replace the on/off switch on an EDCO Floor Stripper TS8 .75L (2017).
필요한 것
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a Phillips screwdriver to remove the screw from the center of the red on/off knob.
Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
Use a socket to remove the four 11/32 inch nuts from the on/off switch bracket.
Use a flathead screwdriver to remove the screw securing the two green ground wires to the switch housing.
Use a flathead screwdriver to loosen the two screws on the right side of the switch assembly securing the black and white wires from the power cord.
Use a flathead screwdriver to loosen the two screws securing the wiring harness's black and white wires to the switch.
Use a 1-1/16 inch wrench or an adjustable wrench to loosen the wiring harness cable's strain relief fitting from the switch housing.
Once the fitting is loose enough to turn by hand, twist the wiring harness cable and fitting counterclockwise until it is fully unthreaded from the switch housing.
