소개
Follow this guide to replace the arbor shaft bearings on an EDCO PRO KL-18 walk behind concrete saw model 39600-HD.
필요한 것
Chock the wheels to prevent the machine from moving while you are working on it.
Flip the ignition switches on the motor and the handle bar into their "OFF" positions.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 9/16 inch socket to remove the two bolts securing the belt guard to the main frame.
Use a 9/16 inch wrench to loosen the lock nut on the belt-tensioner bolt.
Use a 9/16 inch socket to remove the belt-tensioner bolt from the frame.
Use a 9/16 inch wrench to remove the nut securing the ground wire to the engine block.
Use a 9/16 inch wrench to loosen the four nuts securing the engine block to the frame, two on the front and two on the back.
Lift the outermost belt out of its pulley groove and rotate the motor pulley to remove it.
Repeat for the two remaining belts.
Place the guide bar onto the ground out of the way of the blade guard.
Lift the guide bar back up off the ground into its vertical position.
Use a 5/32 inch hex key to loosen the two arbor shaft pulley set screws.
Use a pen to mark the locations of both of the arbor shaft pulleys.
Use a 1/8 inch hex key to loosen the two set screws on the arbor shaft bearing opposite the backing plate.
Use a 1/8 inch hex key to loosen the two set screws on the arbor shaft bearing next to the blade backing plate.
