소개
In these machines, the ceramic valve controls the entire flow of liquid. If it no longer works properly, various faults can occur: No coffee, no steam, no hot water... You can remove the valve and replace it. Sometimes the valve body has a leak.
Note: some pictures come from an older model, but this should not affect the repair
''These instructions can also be used with other Siemens/Bosch models - the models have a similar structure.
필요한 것
Remove all attachments such as water tank, pulp drawer, brew group.
Remove the coffee container lid and take out all the coffee beans.
Lay the machine on its side with the water tank side facing up.
The side panel is essentially held on the ground by five strong catches. Pry up the pegs with a strong prying tool. It's pretty difficult and you need a lot of strength.
If the catches are loose, you can pull the side panel away from below. But it's still stuck in other places.
Use a plastic tool to pry the top cover up a few millimeters and lift off the side panel. Most of the time it's still stuck, especially at the front edge, you have to pull hard.
The ceramic valve is located in the middle of the appliance above the expansion chamber.
To remove it, cables and hoses must be disconnected. The valve is secured on the opposite side with three screws.
You can work easier if you remove the screws first. Proceed to the next step.
Place the machine on its side so that you can easily reach the main circuit board.
Trace the cables from the ceramic valve. Blue-Red-Red-White. The plug must be disconnected from the main circuit board. (second plug from the left)
Lift the main circuit board out about 1 cm and pull off the plug.
Note where the hoses are connected to (photo!) and disconnect them:
The two transparent hoses are unpressurized, the left one leads to the inlet for adding air to the milk frother, the right one to the expansion chamber to drain residual water.
The other three red hoses are pressure hoses, they are attached with a sleeve to push over, which is sometimes very tight: be careful, the connection can break off. (This does not matter if the valve is defective anyway):
The center hose comes from the pump.
The left pressure hose leads to the brew group.
The right-hand pressure hose to the milk frother/hot water outlet.
Work through the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
