소개
For most repairs the ESGE Magic Wand - Bamix has to be disassembled.
필요한 것
이 단계에 사용된 도구:iFixit Precision 4 mm Screwdriver Bit$2.99
Remove two Torx TR10 screws.
Carefully lift off the cover. It is latched at the front.
First try If the bell can be unscrewed. It is fastened with a left-hand thread, so turn it in the "wrong direction", clockwise, to loosen it.
Pull on the knife to remove it
If it does not come off easily, then slide the lower plastic part towards the bell and clamp the motor in a vice. Do not tighten the vice very much, the motor is sensitive.
Use a long screwdriver as a lever between the bell and the shaft. Then carefully unscrew the bell. Reminder: the wrong way round, i.e. clockwise.
Pay attention to the washer between the shaft and the bell, do not lose it.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
