주요 콘텐츠로 건너뛰기
EarStudio ES100 Battery Replacement
필요한 것
  1. EarStudio ES100 Battery Replacement, Back panel removal: 1 단계, 이미지 2개 중 1개 EarStudio ES100 Battery Replacement, Back panel removal: 1 단계, 이미지 2개 중 2개
    • To open the device, push hard on the back panel corner close to the 3.5mm jack with the iFixit opening tool. Take care: the back panel will open suddenly
    • Gently push the pack panel up on all sides of the device
  2. EarStudio ES100 Battery Replacement, Opening: 2 단계, 이미지 1개 중 1개
    • Flip the back panel aside the device. You can now access the battery cable you can safely desolder.
  3. EarStudio ES100 Battery Replacement, Battery reference: 3 단계, 이미지 1개 중 1개
    • The original battery reference SL572035 is discontinued. You can replace it with an alternative battery reference, like the 602035 (3.7 V, 500 mAh) you can find and most spare part markets
    • Warning: do not mismatch with the 602535 battery with a 600 mAh capacity but larger than the 500 mAh one (25 mm versus 20 mm). Make sure the battery size is approximately 20 x 35 x 6 mm.
    • Translation issue. The part section of this article indicates the replacement battery is not available. Actually, it is. Link: https://www.aliexpress.com/item/40010454...
결론
To reassemble the device, glue the battery on the original tape, put the back panel in place making sure not to place it upside-down. Push hard the back panel to clip it to the device main body on all sides. Proceed to a full charge before use.
다른 5명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
Maxime님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Maxime
회원 가입일: 10/27/14
285 평판
안내서 1개를 작성함
5가이드 댓글
I see 602035 batteries on AliExpress that claim to also be 20x35x6mm but now up to 800mAh. Those would work too for over double the original battery life?
Andrew Kachaniwsky - 답글
Yes it will work. I'm using the same battery
Harv -
Just replaced the battery with a 18650 one. Now it'll never die and I can hotswap it if need be :)
Mr. Trvp - 답글
How did you do this, got any images?
Abe Alexander -
Mine had the clips glued together, so they broke. And i'm unable to put it back together to how it was.
Alexander Luft - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 37
전체 시간: 2,844
