주요 콘텐츠로 건너뛰기
Easier way to open
필요한 것
  1. Easier way to open, Open the balance: 1 단계, 이미지 1개 중 1개
    • Since it is not important in the balance to get the adhesive surfaces take a beveled spatula. It's much easier and faster.
  2. Easier way to open: 2 단계, 이미지 2개 중 1개 Easier way to open: 2 단계, 이미지 2개 중 2개
    • Contrary to the other instructions, the board is located directly on the plastic housing. Through the 3 holes water gets into the balance and through the adhesion it spreads over the complete underside of the board
    • The Libra continues to change. Only this time too much water had penetrated which had spread under the board.
    • Clean the underside of the board with acetone. Alternatively, isopropanol.
    • After the board was dry, the scales spoke to me again. And so that water does not penetrate again, I taped the holes with silicone
    • Finally, glue the round cap to the glass plate with a little silicone glue. Because even if the board has a silicone protective coating, it would not be good if Wassser came from above on the SMD components.
결론
Repeat the steps in order to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Marina
회원 가입일: 10/12/17
115 평판
안내서 1개를 작성함
3가이드 댓글
this does not tell you how to open it, only to use a spatula. this is not a guide, it is a waste of time.
David Hopkins - 답글
I support the opinion expressed above. waste of time...
A K - 답글
The 4 load cells are glued to the glass plate.
This means you only have to cut through the adhesive pads from the side
Marina -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 44
전체 시간: 3,160
