소개
This guide will show you how to replace the joysticks on your EasySMX ESM-9110.
필요한 것
Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
거의 끝나갑니다!
결론
