주요 콘텐츠로 건너뛰기
EasySMX ESM-9110 Vibration Motor Replacement
필요한 것
  1. EasySMX ESM-9110 Vibration Motor Replacement, Handle Covers: 1 단계, 이미지 2개 중 1개 EasySMX ESM-9110 Vibration Motor Replacement, Handle Covers: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
  2. EasySMX ESM-9110 Vibration Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
  3. EasySMX ESM-9110 Vibration Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the faceplate.
    • Repeat on the other side of the controller.
  4. EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: 4 단계, 이미지 3개 중 1개 EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: 4 단계, 이미지 3개 중 2개 EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: 4 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to remove the four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • The screw extender should only be used to unscrew two of the six screws. Do not use it for all six.
  5. EasySMX ESM-9110 Vibration Motor Replacement: 5 단계, 이미지 2개 중 1개 EasySMX ESM-9110 Vibration Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle, the controller's backplate is still attached. Do not move the controller too roughly.
  6. EasySMX ESM-9110 Vibration Motor Replacement: 6 단계, 이미지 2개 중 1개 EasySMX ESM-9110 Vibration Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Locate the parts of the vibration motor that are connected to the motherboard
    • Solder these parts of the vibration motor to remove them.
    • There should be two connectors present in your controller, one for each vibration motor.
결론
작성자
2다른 기여자 명과 함께
Melanie Rodriguez
회원 가입일: 03/18/24
406 평판
안내서 4개를 작성함
UMass Dartmouth, Team 2-4, Konn Spring 2024 UMass Dartmouth, Team 2-4, Konn Spring 2024 회원
UMASSD-KONN-S24S2G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 15
전체 시간: 279
