주요 콘텐츠로 건너뛰기
Eatsmart ESBS-01 Battery Replacement
  1. Eatsmart ESBS-01 Battery Replacement, Battery: 1 단계, 이미지 1/2 Eatsmart ESBS-01 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • The LO message on the screen indicates that your digital weight scale is running on low battery so you need to get the replacement battery.
    • This area is where the batteries located, top right corner of the scale.
  2. Eatsmart ESBS-01 Battery Replacement: 2 단계, 이미지 1/2 Eatsmart ESBS-01 Battery Replacement: 2 단계, 이미지 2/2
    • To open the battery compartment, use your finger to gentling push the tip to open the battery compartment.
  3. Eatsmart ESBS-01 Battery Replacement: 3 단계, 이미지 1/2 Eatsmart ESBS-01 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the old batteries from the device by pushing the battery toward the wire side and gentling taking it out.
  4. Eatsmart ESBS-01 Battery Replacement: 4 단계, 이미지 1/2 Eatsmart ESBS-01 Battery Replacement: 4 단계, 이미지 2/2
    • Insert the new batteries in the device.
    • Be aware to place the batteries in the right charge. The positive (+) and negative (-) signs are labeled inside the battery compartment. Place the flat side of the battery to the negative side and the little lip side of the battery to the positive side on the device.
  5. Eatsmart ESBS-01 Battery Replacement: 5 단계, 이미지 1/3 Eatsmart ESBS-01 Battery Replacement: 5 단계, 이미지 2/3 Eatsmart ESBS-01 Battery Replacement: 5 단계, 이미지 3/3
    • Put the cover of the compartment back. You successfully replaced the batteries.
    • You should now see the weight displaying on the screen after the replacement.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elle Luo
회원 가입일: 04/28/17
137 평판
안내서 1개 작성함
UC Davis, Team S4-G1, Cole Spring 2017 UC Davis, Team S4-G1, Cole Spring 2017 회원
UCD-COLE-S17S4G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 44
전체 시간: 1,959
