주요 콘텐츠로 건너뛰기
Echo Chain Saw CS4910 2020 Oiler System Replacement
필요한 것
  1. Echo Chain Saw CS4910 2020 Oiler System Replacement, Turn off the chainsaw: 1 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Turn off the chainsaw: 1 단계, 이미지 2개 중 2개
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS4910 2020 Oiler System Replacement, Loosen the air filter cover: 2 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Loosen the air filter cover: 2 단계, 이미지 2개 중 2개
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the air filter cover: 3 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the air filter cover: 3 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the air filter cover: 3 단계, 이미지 3개 중 3개
    • Remove the air filter cover.
  4. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the air filter: 4 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the air filter: 4 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the air filter: 4 단계, 이미지 3개 중 3개
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  5. Echo Chain Saw CS4910 2020 Oiler System Replacement, Disconnect the spark plug: 5 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Disconnect the spark plug: 5 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Disconnect the spark plug: 5 단계, 이미지 3개 중 3개
    • Use your fingers to pull up and disconnect the spark plug boot.
  6. Echo Chain Saw CS4910 2020 Oiler System Replacement, Loosen the sprocket guard: 6 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Loosen the sprocket guard: 6 단계, 이미지 2개 중 2개
    • Use a 13 mm wrench to loosen and remove the two nuts securing the sprocket guard.
  7. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the sprocket guard: 7 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the sprocket guard: 7 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the sprocket guard: 7 단계, 이미지 3개 중 3개
    • Pull the sprocket guard straight off its two pegs and remove it.
  8. Echo Chain Saw CS4910 2020 Oiler System Replacement, Unclip the saw chain: 8 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Unclip the saw chain: 8 단계, 이미지 2개 중 2개
    • Put on gloves before performing the next two steps.
    • Pull the saw chain away from the tip of the guide bar to unclip it.
  9. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the guide bar: 9 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the guide bar: 9 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the guide bar: 9 단계, 이미지 3개 중 3개
    • Push the guide bar towards the back of the device to unclip the rest of the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar and the saw chain.
  10. Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the bumper spike: 10 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the bumper spike: 10 단계, 이미지 2개 중 2개
    • Use a T25 Torx driver to remove the two 17 mm-long screws securing the bumper spike.
  11. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the bumper spike: 11 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the bumper spike: 11 단계, 이미지 2개 중 2개
    • Pull the bumper spike away from the chassis and remove it.
  12. Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the inner guide plate: 12 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the inner guide plate: 12 단계, 이미지 2개 중 2개
    • Remove the two screws securing the inner guide plate:
    • Use a Phillips driver to remove the 8 mm-long screw.
    • Use a T25 Torx driver to remove the 33 mm-long screw.
  13. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the inner guide plate: 13 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the inner guide plate: 13 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the inner guide plate: 13 단계, 이미지 3개 중 3개
    • Pull the inner guide plate straight off its two pegs and remove it.
  14. Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the brake cover: 14 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the brake cover: 14 단계, 이미지 2개 중 2개
    • Use a 2.5 mm hex key to remove the three 14 mm-long screws securing the brake cover.
  15. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the brake cover: 15 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the brake cover: 15 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the brake cover: 15 단계, 이미지 3개 중 3개
    • Pull the brake cover straight off the chassis and remove it.
    • Make sure the chain brake is in the disengaged position before continuing.
  16. Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the chain brake handle: 16 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the chain brake handle: 16 단계, 이미지 2개 중 2개
    • Use a 4 mm hex key to remove the two screws securing the chain brake handle:
    • One 19 mm-long screw
    • One 23 mm-long screw
  17. Echo Chain Saw CS4910 2020 Oiler System Replacement: 17 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement: 17 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement: 17 단계, 이미지 3개 중 3개
    • Rotate the chain brake handle towards the guide bar recess to unhook the brake lever.
    • Pull the handle away from the chassis to completely remove it.
  18. Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the chain brake assembly: 18 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the chain brake assembly: 18 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the 8 mm-long screw securing the chain brake assembly.
  19. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the chain brake assembly: 19 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the chain brake assembly: 19 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the chain brake assembly: 19 단계, 이미지 3개 중 3개
    • Be careful with this step, as there's tension within the spring. Work slowly to avoid the spring from ejecting.
    • While holding the spring with one hand, slowly push the brake lever out of its recess until the spring is fully extended.
    • Remove the chain brake assembly.
    • During reassembly, insert the spring into its recess first and compress it enough to reinsert the brake lever.
  20. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the retaining plate: 20 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the retaining plate: 20 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the retaining plate: 20 단계, 이미지 3개 중 3개
    • Pull the retaining off the chassis and remove it.
  21. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the torsion spring: 21 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the torsion spring: 21 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the torsion spring: 21 단계, 이미지 3개 중 3개
    • Pull the torsion spring off the chassis and remove it.
  22. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the collar: 22 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the collar: 22 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the collar: 22 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver to pry the collar out of its recess.
    • Remove the collar.
  23. Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the engine cover: 23 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the engine cover: 23 단계, 이미지 2개 중 2개
    • Use a flathead screwdriver, or a 3 mm hex key, to remove the three 18 mm screws securing the engine cover.
  24. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the engine cover: 24 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the engine cover: 24 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the engine cover: 24 단계, 이미지 3개 중 3개
    • Pull the engine cover straight up off the engine.
    • Remove the engine cover.
  25. Echo Chain Saw CS4910 2020 Oiler System Replacement, Loosen the spark plug: 25 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Loosen the spark plug: 25 단계, 이미지 2개 중 2개
    • Use a spark plug socket to loosen the spark plug.
  26. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the spark plug: 26 단계, 이미지 1개 중 1개
    • Remove the spark plug.
  27. Echo Chain Saw CS4910 2020 Oiler System Replacement, Insert a rope: 27 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Insert a rope: 27 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Insert a rope: 27 단계, 이미지 3개 중 3개
    • Insert a piston stopping cord or rope through the cylinder head into the combustion chamber until the crankshaft can no longer turn over.
    • Do not insert the entire cord into the combustion chamber.
  28. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the clutch drum nut: 28 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the clutch drum nut: 28 단계, 이미지 2개 중 2개
    • Use a 13 mm wrench to loosen and remove the clutch drum nut.
  29. Echo Chain Saw CS4910 2020 Oiler System Replacement, Free the clutch drum: 29 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Free the clutch drum: 29 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Free the clutch drum: 29 단계, 이미지 3개 중 3개
    • Remove the washer.
    • Remove the rim sprocket.
  30. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the clutch drum: 30 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the clutch drum: 30 단계, 이미지 2개 중 2개
    • Pull the clutch drum straight off the clutch assembly to remove it.
  31. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the clutch assembly: 31 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the clutch assembly: 31 단계, 이미지 2개 중 2개
    • Use a clutch removal tool to loosen the clutch assembly.
    • Rotate the wrench clockwise instead of counter-clockwise.
  32. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the clutch assembly: 32 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the clutch assembly: 32 단계, 이미지 2개 중 2개
    • Remove the clutch assembly.
  33. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the worm gear assembly: 33 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the worm gear assembly: 33 단계, 이미지 2개 중 2개
    • Pull the worm gear assembly off of the crankshaft and remove it.
  34. Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the oiler cover: 34 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the oiler cover: 34 단계, 이미지 2개 중 2개
    • Use a 3 mm hex key to remove the 18 mm-long screw securing the oiler cover.
  35. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the oiler cover: 35 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the oiler cover: 35 단계, 이미지 2개 중 2개
    • Use a pick tool to remove the oiler cover from its recess.
  36. Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the auto-oiler assembly: 36 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Unfasten the auto-oiler assembly: 36 단계, 이미지 2개 중 2개
    • Use a 3 mm hex key to remove the two 18 mm-long screws securing the auto-oiler assembly.
  37. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the auto-oiler assembly: 37 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the auto-oiler assembly: 37 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers, or your fingers, to remove the auto-oiler assembly from the chassis.
  38. Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the oil filter assembly: 38 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the oil filter assembly: 38 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Oiler System Replacement, Remove the oil filter assembly: 38 단계, 이미지 3개 중 3개
    • Use a pick tool to pull the oil filter assembly through its hole in the chassis until you can grip it with your fingers.
    • Use your fingers to remove the rest of the oil filter assembly.
결론
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,178 평판
안내서 1,040개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 39
전체 시간: 1,045
