주요 콘텐츠로 건너뛰기
Echo Chain Saw CS4910 2020 Piston Assembly Replacement
필요한 것
  1. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Turn off the chainsaw: 1 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Turn off the chainsaw: 1 단계, 이미지 2개 중 2개
    • Make sure you have the ignition switch turned off before starting your repair.
    • The chainsaw should be cool to the touch before continuing.
  2. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Loosen the air filter cover: 2 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Loosen the air filter cover: 2 단계, 이미지 2개 중 2개
    • Use your fingers to loosen the air filter cover knob.
  3. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the air filter cover: 3 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the air filter cover: 3 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the air filter cover: 3 단계, 이미지 3개 중 3개
    • Remove the air filter cover.
  4. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the air filter: 4 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the air filter: 4 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the air filter: 4 단계, 이미지 3개 중 3개
    • During reassembly, clean the air filter with compressed air or with light brushing before reinstalling it.
  5. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Disconnect the spark plug: 5 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Disconnect the spark plug: 5 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Disconnect the spark plug: 5 단계, 이미지 3개 중 3개
    • Use your fingers to pull up and disconnect the spark plug boot.
  6. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Loosen the sprocket guard: 6 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Loosen the sprocket guard: 6 단계, 이미지 2개 중 2개
    • Use a 13 mm wrench to loosen and remove the two nuts securing the sprocket guard.
  7. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the sprocket guard: 7 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the sprocket guard: 7 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the sprocket guard: 7 단계, 이미지 3개 중 3개
    • Pull the sprocket guard straight off its two pegs and remove it.
  8. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unclip the saw chain: 8 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unclip the saw chain: 8 단계, 이미지 2개 중 2개
    • Put on gloves before performing the next two steps.
    • Pull the saw chain away from the tip of the guide bar to unclip it.
  9. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the guide bar: 9 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the guide bar: 9 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the guide bar: 9 단계, 이미지 3개 중 3개
    • Push the guide bar towards the back of the device to unclip the rest of the saw chain.
    • Pull the guide bar away from the device to separate the saw chain from the clutch drum.
    • Remove the guide bar and the saw chain.
  10. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the engine cover: 10 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the engine cover: 10 단계, 이미지 2개 중 2개
    • Use a flathead screwdriver, or a 3 mm hex key, to remove the three 18 mm screws securing the engine cover.
  11. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the engine cover: 11 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the engine cover: 11 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the engine cover: 11 단계, 이미지 3개 중 3개
    • Pull the engine cover straight up off the engine.
    • Remove the engine cover.
  12. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Disconnect the carburetor: 12 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Disconnect the carburetor: 12 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Disconnect the carburetor: 12 단계, 이미지 3개 중 3개
    • Before performing this step, put on safety glasses to avoid any fuel spraying in your eyes.
    • Use your fingers to pull the top-most fuel pipe out of the carburetor.
  13. Echo Chain Saw CS4910 2020 Piston Assembly Replacement: 13 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement: 13 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement: 13 단계, 이미지 3개 중 3개
    • Lift the choke rod out of its recess in the chassis.
    • Twist the rod counter-clockwise to disconnect it from the carburetor.
    • Remove the choke rod.
  14. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the carburetor: 14 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the carburetor: 14 단계, 이미지 2개 중 2개
    • Remove the four screws securing the carburetor and the air filter adapter:
    • Use a 3 mm hex key to remove the two 20 mm-long screws.
    • Use a 4 mm hex key to remove the two 53 mm-long screws.
  15. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the air filter adapter: 15 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the air filter adapter: 15 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the air filter adapter: 15 단계, 이미지 3개 중 3개
    • Pull the air filter adapter straight off the carburetor and remove it.
  16. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Reposition the carburetor: 16 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Reposition the carburetor: 16 단계, 이미지 2개 중 2개
    • With the carburetor's choke valve facing you, tilt the carburetor up and to the left to expose the right-most fuel pipe.
  17. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Disconnect the right fuel pipe: 17 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Disconnect the right fuel pipe: 17 단계, 이미지 2개 중 2개
    • Use your fingers to disconnect the right-most fuel pipe.
  18. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the carburetor: 18 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the carburetor: 18 단계, 이미지 2개 중 2개
    • Lift the carburetor straight off the throttle rod and remove it.
    • Realign throttle rod upon reassembly.
  19. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the handle: 19 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the handle: 19 단계, 이미지 2개 중 2개
    • Remove the five screws securing the handle:
    • Use a 4 mm hex key to remove the four 24 mm-long screws (on the side and bottom).
    • Use a 3 mm hex key to remove the 18 mm-long screw.
  20. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the handle: 20 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the handle: 20 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the handle: 20 단계, 이미지 3개 중 3개
    • Pull the handle towards the rear of the device to remove it.
  21. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the intake insulator: 21 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the intake insulator: 21 단계, 이미지 2개 중 2개
    • Use a 3 mm hex key to remove the two 20 mm-long screws securing the intake insulator.
  22. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the collar: 22 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the collar: 22 단계, 이미지 2개 중 2개
    • Use a pick tool to remove the insulator intake collar.
  23. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Reposition the intake bellows: 23 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Reposition the intake bellows: 23 단계, 이미지 2개 중 2개
    • Use a flathead screwdriver to fold the lip of the intake bellows inside the intake insulator.
  24. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the intake insulator: 24 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the intake insulator: 24 단계, 이미지 2개 중 2개
    • Lift the intake insulator out of its recess and remove it.
  25. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the bellows holder: 25 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the bellows holder: 25 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the bellows holder: 25 단계, 이미지 3개 중 3개
    • Slide the bellows holder off the intake bellows and remove it.
  26. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the intake bellows: 26 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the intake bellows: 26 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the intake bellows: 26 단계, 이미지 3개 중 3개
    • Insert a flathead screwdriver between the intake bellows and the cylinder head.
    • Pry with the screwdriver to separate the intake bellows from the cylinder head.
    • Remove the intake bellows.
  27. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Loosen the spark plug: 27 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Loosen the spark plug: 27 단계, 이미지 2개 중 2개
    • Use a spark plug socket wrench to loosen the spark plug.
  28. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the spark plug: 28 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the spark plug: 28 단계, 이미지 2개 중 2개
    • Pull the spark plug straight out of the cylinder head and remove it.
  29. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Loosen the decompression valve assembly: 29 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Loosen the decompression valve assembly: 29 단계, 이미지 2개 중 2개
    • Use a 9/16 inch wrench to loosen the decompression valve assembly.
  30. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the decompression valve assembly: 30 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the decompression valve assembly: 30 단계, 이미지 2개 중 2개
    • Pull the decompression valve assembly straight out of the cylinder head and remove it.
  31. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the muffler: 31 단계, 이미지 1개 중 1개
    • Use a 4 mm hex key to remove the two 23 mm-long screws securing the muffler.
    • Use a 3 mm hex key to remove the 10 mm-long screw securing the muffler plate.
  32. Echo Chain Saw CS4910 2020 Piston Assembly Replacement: 32 단계, 이미지 1개 중 1개
    • Remove the muffler plate.
  33. Echo Chain Saw CS4910 2020 Piston Assembly Replacement: 33 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement: 33 단계, 이미지 2개 중 2개
  34. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the muffler: 34 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the muffler: 34 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the muffler: 34 단계, 이미지 3개 중 3개
    • Pull the muffler straight out of its recess and remove it.
  35. Echo Chain Saw CS4910 2020 Piston Assembly Replacement: 35 단계, 이미지 1개 중 1개
    • Remove the exhaust gasket.
  36. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the cylinder head: 36 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Unfasten the cylinder head: 36 단계, 이미지 2개 중 2개
    • Use a 4 mm hex key to remove the four 25 mm-long screws securing the cylinder head.
  37. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the cylinder head: 37 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the cylinder head: 37 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the cylinder head: 37 단계, 이미지 3개 중 3개
    • Lift the cylinder head away from the chassis to expose the piston.
    • Remove the cylinder head.
    • During reassembly, perform the following:
    • Make sure the two black piston rings are aligned in their grooves so the piston can compress properly in the cylinder head.
    • Apply two-stroke oil to the piston head and the cylinder walls before reinserting the piston.
  38. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the snap rings: 38 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the snap rings: 38 단계, 이미지 2개 중 2개
    • Use snap ring pliers, or a flathead screwdriver, to remove one of the piston snap rings.
    • Repeat this procedure for the snap ring on the opposite side of the piston.
  39. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Reposition the chain saw: 39 단계, 이미지 2개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Reposition the chain saw: 39 단계, 이미지 2개 중 2개
    • Flip the chain saw on its side so the clutch drum is facing upward.
  40. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the piston pin: 40 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the piston pin: 40 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the piston pin: 40 단계, 이미지 3개 중 3개
    • Grip the bottom of the piston.
    • Use a hammer and a pin punch to tap the piston pin through its recess.
    • The piston swings freely on the crankshaft. Be sure to stabilize the piston with your hand as you tap on the pin punch.
    • Alternatively, you can use a piston support tool or a block of wood to keep the piston steady.
    • Remove the piston pin.
  41. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the piston assembly: 41 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the piston assembly: 41 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the piston assembly: 41 단계, 이미지 3개 중 3개
    • Pull the piston off of the piston rod to disconnect it from the crankshaft.
    • Remove the piston, its needle bearing, and the two washers.
  42. Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the cylinder gasket: 42 단계, 이미지 3개 중 1개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the cylinder gasket: 42 단계, 이미지 3개 중 2개 Echo Chain Saw CS4910 2020 Piston Assembly Replacement, Remove the cylinder gasket: 42 단계, 이미지 3개 중 3개
    • Use a pair of pliers to remove the cylinder head gasket from the crankcase.
    • During reassembly, make sure to replace the gasket with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,407 평판
안내서 1,040개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 9
지난 30일: 32
전체 시간: 1,227
