주요 콘텐츠로 건너뛰기
Echo Dot 3 Mic/LEDs/Button Replacement
필요한 것
  1. Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: 1 단계, 이미지 2개 중 1개 Echo Dot 3 Mic/LEDs/Button Replacement, Outer Shell: 1 단계, 이미지 2개 중 2개
    • Turn your Dot around, so that the Barcode is facing up, and the buttons down.
  2. Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": 2 단계, 이미지 2개 중 1개 Echo Dot 3 Mic/LEDs/Button Replacement, Bottom "Lid": 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $3.99
    • Using a Spudger remove the Lid.
    • There's Adhesive under the lid, so the best way to get it off, is to go all the way around with the Spudger
  3. Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: 3 단계, 이미지 3개 중 1개 Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: 3 단계, 이미지 3개 중 2개 Echo Dot 3 Mic/LEDs/Button Replacement, Shell unscrewing: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    TR6 Torx Security Screwdriver
    $5.99
    • Unscrew the 4 T6 Torx screws using the Right Screwdriver
    • After unscrewing, you can slowly lift the shell, and you'll be greeted by the insides of the Dot!
  4. Echo Dot 3 Mic/LEDs/Button Replacement, Insides: 4 단계, 이미지 3개 중 1개 Echo Dot 3 Mic/LEDs/Button Replacement, Insides: 4 단계, 이미지 3개 중 2개 Echo Dot 3 Mic/LEDs/Button Replacement, Insides: 4 단계, 이미지 3개 중 3개
    • Unscrew the 3 T6 Torx screws,
    • and lift the flex cable connector.
    • After that, very carefully remove the PCB/Power supply (no idea).
  5. Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: 5 단계, 이미지 2개 중 1개 Echo Dot 3 Mic/LEDs/Button Replacement, Middle part: 5 단계, 이미지 2개 중 2개
    • Remove the 4 T6 Torx screws (2 different lengths!)
    • Slowly Remove the Middle part
    • Be very careful while removing the middle part, so that you don't damage the cable!
  6. Echo Dot 3 Mic/LEDs/Button Replacement, Top part: 6 단계, 이미지 3개 중 1개 Echo Dot 3 Mic/LEDs/Button Replacement, Top part: 6 단계, 이미지 3개 중 2개 Echo Dot 3 Mic/LEDs/Button Replacement, Top part: 6 단계, 이미지 3개 중 3개
    • Remove the 4 T6 Torx screws,
    • and lift the plastic to remove it.
  7. Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: 7 단계, 이미지 3개 중 1개 Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: 7 단계, 이미지 3개 중 2개 Echo Dot 3 Mic/LEDs/Button Replacement, Motherboard: 7 단계, 이미지 3개 중 3개
    • Simply flip the device to separate the:
    • Motherboard and
    • Buttons from each other.
결론
Congrats! To put together your Echo Dot, simply follow the instructions backward! Have a nice day!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
ashlynn
회원 가입일: 05/10/22
190 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 33
전체 시간: 815
