소개
If The blue light on your monitor is turning on, but the display isn't then here is a guide on how to replace it. The only tool you will need is a #1 Philips head screwdriver.
필요한 것
Take your monitor and face in down so that the back is facing up. There will be four screws on each corner of the monitors back cover. Unscrew each one and set them to the side. Remove four 1.2 mm Phillips #1 screws.
거의 끝나갑니다!
결론
