주요 콘텐츠로 건너뛰기
EchoMaster MRC-WLP43 Wire Port Replacement
필요한 것
  1. EchoMaster MRC-WLP43 Wire Port Replacement, Wire Port: 1 단계, 이미지 1개 중 1개
    • Take your monitor and face in down so that the back is facing up. There will be four screws on each corner of the monitors back cover. Unscrew each one and set them to the side. Remove four 1.2 mm Phillips #1 screws.
    • Don't lose your screws!
  2. EchoMaster MRC-WLP43 Wire Port Replacement: 2 단계, 이미지 2개 중 1개 EchoMaster MRC-WLP43 Wire Port Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully lift the back along with the screen then flip it around slowly so the back is placed down on the table.
    • The back is connected to the motherboard and screen so lift with caution!
    • Lift your screen above the motherboard and set it down.
  3. EchoMaster MRC-WLP43 Wire Port Replacement: 3 단계, 이미지 1개 중 1개
    • There are three screws on the motherboard. Unscrew each one of the three 1.4 mm Phillips #1 screws.
  4. EchoMaster MRC-WLP43 Wire Port Replacement: 4 단계, 이미지 2개 중 1개 EchoMaster MRC-WLP43 Wire Port Replacement: 4 단계, 이미지 2개 중 2개
    • Once the screws are out, you can then remove the yellow strip connecting the screen to the motherboard.
    • There is a black tab that you can carefully flip up with your fingernail or a flathead screwdriver. Once it's flipped up you can easily slide the yellow ribbon out.
  5. EchoMaster MRC-WLP43 Wire Port Replacement: 5 단계, 이미지 2개 중 1개 EchoMaster MRC-WLP43 Wire Port Replacement: 5 단계, 이미지 2개 중 2개
    • When everything is unscrewed and removed you can take your motherboard out.
    • Your charger port is attached to the motherboard. To replace it you can simply retrace these steps.
결론
작성자
2다른 기여자 명과 함께
Cheska king
회원 가입일: 02/09/23
691 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 200
