주요 콘텐츠로 건너뛰기
Eclipse 180BL Battery Replacement
필요한 것
  1. Eclipse 180BL Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the two screws located on the bottom of the device with a phillips head screw driver.
    • The two screws can be removed using the PH00 head from the iFixit repair toolkit.
    • Both screws are 1/8 inch in length.
    • The bottom cap will come off to reveal the inside main component.
  2. Eclipse 180BL Battery Replacement: 2 단계, 이미지 2개 중 1개 Eclipse 180BL Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
    • Hold on the sides with your fingers, and push to release from the top.
  3. Eclipse 180BL Battery Replacement: 3 단계, 이미지 3개 중 1개 Eclipse 180BL Battery Replacement: 3 단계, 이미지 3개 중 2개 Eclipse 180BL Battery Replacement: 3 단계, 이미지 3개 중 3개
    • The plastic LCD cover and the key pad will now be loose; they were held in place by the tension between the case and the internal main component.
    • Locate the large square pack with a black and red wire coming out of it, this is the battery.
    • Cut the red and black wires to remove the old battery.
  4. Eclipse 180BL Battery Replacement: 4 단계, 이미지 1개 중 1개
    • To Replace, connect the two new lines ( red and black) between the new battery and the device.
    • You have successfully replaced the battery!
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Thomas Schwarz
회원 가입일: 09/07/15
499 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 31
전체 시간: 1,779
