주요 콘텐츠로 건너뛰기
Eclipse 180BL LCD Screen Cover Replacement
필요한 것
  1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: 1 단계, 이미지 1/3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: 1 단계, 이미지 2/3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: 1 단계, 이미지 3/3
    • To start, remove the two screws located at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
    • Both Screws are 1/8 inch in length.
    • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
    • Be careful, as releasing the tension will cause all parts to become loose and separate.
  2. Eclipse 180BL LCD Screen Cover Replacement: 2 단계, 이미지 1/3 Eclipse 180BL LCD Screen Cover Replacement: 2 단계, 이미지 2/3 Eclipse 180BL LCD Screen Cover Replacement: 2 단계, 이미지 3/3
    • The LCD screen cover is placed into its slot after all the inner components are replaced.
    • Get the new screen cover, and carefully place in alignment with the outer shell.
    • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
결론
Thomas Schwarz
회원 가입일: 09/07/15
499 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 회원
USFSM-STEWART-F15S1G2
5 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 543
