주요 콘텐츠로 건너뛰기
Eclipse 180G2 MP3 Video Player Buttons Replacement
필요한 것
  1. Eclipse 180G2 MP3 Video Player Buttons Replacement, Outer Case: 1 단계, 이미지 1/2 Eclipse 180G2 MP3 Video Player Buttons Replacement, Outer Case: 1 단계, 이미지 2/2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player Buttons Replacement, Remove inner circuit from case shell: 2 단계, 이미지 1/3 Eclipse 180G2 MP3 Video Player Buttons Replacement, Remove inner circuit from case shell: 2 단계, 이미지 2/3 Eclipse 180G2 MP3 Video Player Buttons Replacement, Remove inner circuit from case shell: 2 단계, 이미지 3/3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player Buttons Replacement, Removing the Screen: 3 단계, 이미지 1/1
    • Freed from the internal space of the device, the LCD screen as well as the buttons will simply fall out of the face of the device. They can now easily be replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Walker
회원 가입일: 01/15/15
373 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-4, Tanski Winter 2015 USF Tampa, Team 1-4, Tanski Winter 2015 회원
USFT-TANSKI-W15S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 1,327
