주요 콘텐츠로 건너뛰기
Eclipse MTE28VGM Lens Cover Replacement
필요한 것
  1. Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: 1 단계, 이미지 1/3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: 1 단계, 이미지 2/3 Eclipse MTE28VGM Lens Cover Replacement, Lens Cover: 1 단계, 이미지 3/3
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM Lens Cover Replacement: 2 단계, 이미지 1/3 Eclipse MTE28VGM Lens Cover Replacement: 2 단계, 이미지 2/3 Eclipse MTE28VGM Lens Cover Replacement: 2 단계, 이미지 3/3
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM Lens Cover Replacement: 3 단계, 이미지 1/2 Eclipse MTE28VGM Lens Cover Replacement: 3 단계, 이미지 2/2
    • Using the plastic spudger, pry the plastic lens cover off of the camera.
    • Attach the replacement plastic lens cover to the camera.
결론
Tyler Hudgens
회원 가입일: 09/29/16
288 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-1, Harley Fall 2016 IUPUI, Team 2-1, Harley Fall 2016 회원
IUPUI-HARLEY-F16S2G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 196
