소개
This guide is required when there is no audio coming from the device as a result of a broken speaker. To replace the speaker, it is required to solder the replacement speaker to the motherboard. This is a safety hazard and specific soldering equipment is needed. When soldering, protective equipment needs to be warn for caution.
필요한 것
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws
거의 끝나갑니다!
결론
